Plumbersmateuk Posted September 11, 2017 Author Posted September 11, 2017 1 minute ago, AliMcLeod said: The starting point for your negotiation could be that he'll have been making a "profit" using the flat rate scheme. So, if his hourly rate is (for example) £100 ex-vat, he'd (in a standard VAT-rated engagement) be charging £120 to customers, then paying £13.20 (assuming 11% - you'd need to check) to the VAT man, meaning a net hourly rate of £106.80. If you get him to zero-rate his invoice at £112.36, he'll owe the taxman £12.36 and get his net £100 per hour. He may well see that as a £6.80 discount on his hourly rate, however. Yep that is virtually what I have put in an email to him so will keep fingers crossed.
Thedreamer Posted September 11, 2017 Posted September 11, 2017 If your supplier is registered under the VAT flat rate scheme, then the following should happen: If the supply provided, qualifies as being zero rated as site preparation costs, then they should issue an invoice to you which shows VAT charged at 0%. The supplier's own VAT records will be based upon what ever the flat rate % is for their industry. My understanding is the flat rate % is based on a composite of standard, reduced or zero rated supplies averaged within a particular industry, unless they are operating as a limited cost business in which it's case it always 16.5%.
Plumbersmateuk Posted September 12, 2017 Author Posted September 12, 2017 8 hours ago, Thedreamer said: If your supplier is registered under the VAT flat rate scheme, then the following should happen: If the supply provided, qualifies as being zero rated as site preparation costs, then they should issue an invoice to you which shows VAT charged at 0%. The supplier's own VAT records will be based upon what ever the flat rate % is for their industry. My understanding is the flat rate % is based on a composite of standard, reduced or zero rated supplies averaged within a particular industry, unless they are operating as a limited cost business in which it's case it always 16.5%. Yep that's as I read it but I have to get him to agree to do it at zero, which I don't think is going to happen.
Temp Posted September 12, 2017 Posted September 12, 2017 11 hours ago, Thedreamer said: If your supplier is registered under the VAT flat rate scheme, then the following should happen: If the supply provided, qualifies as being zero rated as site preparation costs, then they should issue an invoice to you which shows VAT charged at 0%. The supplier's own VAT records will be based upon what ever the flat rate % is for their industry. My understanding is the flat rate % is based on a composite of standard, reduced or zero rated supplies averaged within a particular industry, unless they are operating as a limited cost business in which it's case it always 16.5%. That's correct but it means anyone on the flat rate scheme is out of pocket if they take on zero rated jobs. Earlier I posted a comment I found on an accountancy site that suggested companies that regularly do zero rated work should avoid the flat rate scheme for that reason.
