Hi all - I started a thread a short while ago about whether I need a VCL layer in my roof buildup but it disappeared under the waves unfortunately, and I really need some help with this if possible. Can I retry?
I have been quoted £4,500 for fitting the VCL to the roof structure as part of the whole boarding/skimming quote which seems ludicrous. We have been told by BC that we need a VCL but I have the feeling this is a decision made without due consideration - and one that is going to cost me in hard earned bunce. (Like when I was told I wouuld need 2x 11kWh ASHPs by one supplier but my calcs using the heat loss spreadsheet indicated I would need a single 8kWh... but I digress)
So, the roof make up we have from inside is:
plaster board
200mm rockwool
150mm PIR (actually composite panel, so clad in metal sheet)
I have taped the seams between the composite panels and foamed round the edges so am happy that this layer is airtight. BC want me to put a VCL between the platerboard and rockwool, so:
plasterboard
VCL
200mm rockwool
150mm PIR
I'm worried that, at best, this superfluous or at worst will just trap moisture when humid air seeps through the inevitable screw holes etc.
I have tried to find an interstitial condensation calculatoir on-line but had no luck, other than this German one: https://www.ubakus.de/u-wert-rechner/?  but am struggling to make sense of it.
Can anyone shed any light on this?
Thank you so much!
Tom
VCL isn’t a requirement BC often prefer it
As a plastering contractor I price lots of jobs each year Some specifing VCL
Most not
I didn’t use one on our previous build and won’t on this one
I would prefer a foil backed board But the majority of house builders don’t even do that When I quote for VCL it’s normally around £9 m2 supply and fit
Thanks nod. It's just unclear why BC say they want it - and it would be good to be able to convince them otherwise.
When you provide the VCL what do you supply?
They should really have said that they would prefer it
It’s normally Architects that add it to the spec About 50-50
If it’s in your building materials spec You are stuck with it If it’s not thank BC for the ADVISE and tell them your good
Ah, that's the rub unfortunately, the roof build-up has been altered since the architects plans were drawn up, so we're playing it all by ear tbh.
Am still trying to get hold of BC...
Screws don't leave holes unless you take them out again, and they will be into timber so it isn't a worry. What you might have is holes and gaps at light fittings, but this should be avoidable.
That seems rather a lot if the ceiling is at bare joist stage.
What do you reckon? 2 workers x 2 days? £800. add material, add margin 20%.
Or Nod's idea of the foil backed board will be fine for bco too.
Thanks both for your input. Spoke to a firm who would do a condensation risk analysis for me (taking in to account the steel rafters, z purlins etc) and it seems the calculation would take the best part of a day and cost over £1k - and their hunch is that I would need a VCL anyway. So, have bitten the bullet and instructed the boarders to put a VCL in. Gone for a membrane over foil-backed boards due to the detailing needed at board/steel junctions. What's another £4k eh?
