I’m going to be framing out round my stove to form a chimney breast with tv mounted in it (tv above stove is bad idea I no) an was going to use u and c track rather than timber but can’t figure out how to form the left to rights off of the front to backs. Really bad terminology but hopefully somebody understands and can explain. I can put the top rail on ceiling but for the bottom rail that’s above stove what do you use to support it coming of the side partitions?
Yep
Use the track Snip the upright edge then fold either her You can then cut some stud and push it inside to form a strong box section
26 minutes ago, nod said:
Yep
And say that section was spanning 900mm do you think two rails would be strong enough to take a tv an mount or would it need to be beefed up?
8 hours ago, Barryscotland said:
And say that section was spanning 900mm do you think two rails would be strong enough to take a tv a mount or would it need to be beefed up?Yes
