Hi
Creating an ensuite. What subfloor do I put direct onto floor joists?
No underfloor heating
Marine ply is very expensive and as usual I'm on a budget! But must do it right!
14 hours ago, Dee said:
Chipboard????
Yes, moisture resistant makes sense as it’s not that much more anyway. Unless you are looking to have a bare floor varnished or something then you would need marine ply.
Great. Thanks for your input.
Don't shoot me down but I'm pondering using composite woodgrain decking?!
Couple of problems spring to mind, as the water will go between the decking boards you will need a drain underneath and need everything under the decking (and part way up the walls to above decking height at least) to be fully sealed/tanked.
decking boards are not easy to keep clean and soap/skin/shower crud may be a pain
I'm going for moisture resistant caber floor and tanking around wet areas (bathroom and shower area)
Edited by jayc89
  • Like 2
