Andeh Posted September 2, 2023 Posted September 2, 2023 Woke up to see the inverter acting like the below, doesn't seem positive! It's under warranty, and 3 months old, but thought I'd ask whilst the shop is closed over the weekend!
SteamyTea Posted September 2, 2023 Posted September 2, 2023 (edited) I assume you have disconnected it and then reconnected. Solis Alarm Codes https://usservice.solisinverters.com/support/solutions/articles/73000560423-solis-inverter-alarm-codes-complete-list- Edited September 2, 2023 by SteamyTea
ProDave Posted September 2, 2023 Posted September 2, 2023 It looks to me like a component failure. As if it is powering up, but then tries to do something that draws a bit of power and the power supply trips. It starts and tries again in an endless loop. I doubt there is an entry in the fault codes for "power supply component goosed"
Andeh Posted September 2, 2023 Author Posted September 2, 2023 Thanks! Having turned it off for 30mins and turned it on again, all seems fine with it and it's generating a normal amount for this time of the morning.
SteamyTea Posted September 2, 2023 Posted September 2, 2023 1 hour ago, Andehh said: Having turned it off for 30mins and turned it on again, all seems fine Flick those faulty LEDs and see if it affects it.
