Cognis0 Posted August 15, 2023 Share Posted August 15, 2023 I've removed the ceiling in our lean-to extension to form a nice airy/open kitchen/family space. I plan to insulate between the rafters with 140mm flexible wood-fibre and then over the top with 60mm wood-fibre t&g. On top of this, for VCL/airtightness, I was thinking of using Passive Purple liquid membrane in white which would also provide a decorative finish. This should avoid the need to scim plaster and paint. Does anyone have any comments/see flaws in this plan? Link to comment Share on other sites More sharing options...
Conor Posted August 15, 2023 Share Posted August 15, 2023 Can't see that looking good at all, I'm afraid. And you've the issue of penetrations for lights etc that won't be sealed. You could use PIR under the joists , tape, the. Batten out and board under. Gives you a void to run your wiring etc. Link to comment Share on other sites More sharing options...
Iceverge Posted August 16, 2023 Share Posted August 16, 2023 If you have no penetrations I would rather render directly to the woodfiber as an airtightness layer rather than purple passive. A a clay or lime render may be needed if you wish to retain the breathability of the wood fiber. Having used a fair few tubs of the Soudal airtight paint it yellows in sunlight and has a texture a bit like fiberglass so I don't think it's a suitable final finish. Caution of blocking any airflow gaps with the batts if you have under sarking ventilation in the roof. Link to comment Share on other sites More sharing options...
Cognis0 Posted August 16, 2023 Author Share Posted August 16, 2023 That's helpful, thanks Iceverge... 10 hours ago, Iceverge said: If you have no penetrations I would rather render directly to the woodfiber as an airtightness layer rather than purple passive. A a clay or lime render may be needed if you wish to retain the breathability of the wood fiber. Having used a fair few tubs of the Soudal airtight paint it yellows in sunlight and has a texture a bit like fiberglass so I don't think it's a suitable final finish. Caution of blocking any airflow gaps with the batts if you have under sarking ventilation in the roof. Link to comment Share on other sites More sharing options...
