We are thinking of buying a house but as you can see from the picture an extended bedroom has basically been cut in two because of existing structural beams. Is it possible to cut the width of these supports/ walls in order to unify the room as well as bringing more light to the back area of the room? It would make the room more attractive and usable. Would it be massively expensive?
I am thinking is the opening is the original width of the window in the room before the extension and this was the cheap option to just keep the lintel that was there.
It is probably possible to widen the opening and replace with a much longer and stronger lintel, but it won't be cheap or simple.
Yes
Whilst it’s a straightforward job It would be destructive
