Accumulator (mains booster) vessels - Same nominal volume, huge size difference.
Both of the below vessels have a nominal volume of 100L (ok, ST is 110, PW is 100). But ST is 558x540x1026, PW is 720x470x470. What am I missing?
(ignore location for now)
#1 GWS PressureWave - PWB-100LH (horizontal)
- Pump not mentioned, I assume needs to be supplied separately
- The dimensions are very small for a 100L nominal device, not sure why the Stuart Turner ones are so much bigger
#2 Stuart Turner Mainsboost MB-200SH
- As can be seen much larger device, which even sticks beyond the door. Still, 110L nominal so I'm not sure what's going on
- Pump not depicted
ummm, the Mainsboost is a 200l vessel?
I'm guessing they're just being more conservative about the life of the diaphragm.
edit: also the *system* has a rating of 3.5bar uplift, so the end volume is variable. The other tank is just talking about it's full capacity I'd think.
Edited by dpmiller
Mainsboost says 'nominal volume 110L' though, which is the same as the GWS says...
I am suspecting you are right, "too good to be true" usually is ;) - but it's still hard to see the real situation. Basically
PW: 0.24x0.72 = 0.13 -> 130L volume of the cylinder outer hull
MB: 0.28x1 = 0.28 -> 280L volume of cylinder outer hull
So indeed I suspect what one company calls nominal is the other's "maximal" or whatever.
