Tennentslager Posted August 20, 2017 Posted August 20, 2017 Been fitting new doors and a couple of the handles are sticky...the action isn't smooth and seems like a catch or obstruction at about half way down when you depress to open the door. The sticky ones also don't pop back up like they should. I've checked everything and suspect they are shit handles...client bought from B&Q
Onoff Posted August 20, 2017 Posted August 20, 2017 Mr Sheen? Works wonders on saw blades, hinges etc.
Oz07 Posted August 20, 2017 Posted August 20, 2017 Latch or spindle hole may be tight. Wiggle spade bit round usually solves 1
Tennentslager Posted August 21, 2017 Author Posted August 21, 2017 Thanks @Oz07 Worked it out. Removed this screw...small amount of splinter from where this breaking through the door was interfering with the mechanism. At this 2 o'clock position it's next to the catch on the cam behind. Did the same on the other sticky one and now both are as smooth as a squid in Vaseline after a few Martinis ?
