So way back in 2006 our builder fitted sealed units into our wood window frames. They used a low modulus sealer of some sort to seal the glass into the frame,  did a neat job and wiped off any squeeze out.
However the sealer left a residue on the wood that is still haunting us today. No matter how many times I sand and wipe down with meths I can't stop getting fish eye when using Sadolins. Im repainting a windows at the moment and had sanded and wiped one area three times and still it's like painting a wax candle in a few spots.
So if you are about to fit windows I strongly recommend using a paintable sealer or mask off the wood until its fully dry to prevent issues with squeeze out forever contaminating the wood.
If anyone knows of a clear primer or similar that solves this let me know!
If you can remember that far back or know the brand then if it smelt of Vinegar when curing then washing with white vinegar to loosen it before using a scouring pad may help.
1 hour ago, Discoeye said:
Have you tried turpentine ???? I have always had good results with this .
Not yet !  Have tried white spirt though.
Automotive panel wipe, the solvent based one. Designed specifically to remove silicones prior to painting.
