Garden Shed - Do I need planning permission ?
Janan Jai
Any other questions, please ask. Below are the details and image attached for your reference.
Size - 22.5 square metres
Rough Size - 5m x 4.5m
Council - Newham
Type of the new build - Garden shed
Property - Mid terraced
Property age - 1920's built
Purpose of the shed - Storage only
  • PVC double door and one window
  • concrete block built (I believe the builder may use a little bit of bricks ?
  • Height - Wont exceed 2.5m
  • Power supply with lights to the shed
  • Tile flooring
  • No water supply or beds to be placed inside the shed. Will only Just storage.
  • Felt roof
  • Will be leaving 50cms of space on 3 sides of the shed (left/right/back sides) for moving around if required
Attached image temp1_Untitled.thumb.png.bc0c88f7a3f9afd5ef4e9bf2e930e7bc.png
Edited by Janan Jai
You won't need Building Control Approval as it's "constructed substantially of non-combustible materials". If you changed to a timber construction then you woukd require Building Control Approval.
Because it’s within a meter of the boundary ( I believe !)
