cwr Posted July 1, 2023 Posted July 1, 2023 Hi folks I need to cut down a 20mm thick slate hearth. One cut edge will be against a wall at the back once installed, but a cut along a side will be visible so needs to be pretty god. How best to make a nice neat square cut? Can a suitable disc be fitted a circular saw? Thanks
Dave Jones Posted July 1, 2023 Posted July 1, 2023 clamp timber to it to use as a guide for the blade, cut slow and plenty of water.
cwr Posted July 1, 2023 Author Posted July 1, 2023 OK. Do you mean with an angle grinder or circular saw?
Dave Jones Posted July 1, 2023 Posted July 1, 2023 would have thought a 9 inch grinder and new diamond blade would make short work if it. You can buy a bull nose wheel for the grinder as well to soften and smooth the edges after. The lads who did our hearth had one made a lovely job of it.
Big Jimbo Posted July 1, 2023 Posted July 1, 2023 Cut with an angle grinder. Ebay will get you a set of diamond polishing pads for a small angle grinder. Go down using the grades and you will get a perfect finish. I have a set that i have used a few times on granite for window cills etc. A perfect polished finished to a meter long cut takes about 10 mins.
