Thought it was my imagination. Heating off . Pump is off . But a bedroom floor is noticeably warm ( curtains closed so not sunlight ) .
I believe a uvc still has a diverter valve . If that fails / sticks could calling for dhw ( even though ufh pump off ) bleed warm water into it ???
Anything else to check ??
Get temp readings at the manifold that services that area. See if the return pipe is warmer than the flow.
Check the actuator hasn't come loose allowing the pin to come up.
Check flow meters?
Any pumps running that shouldnt?
Edited by Temp
