markocosic Posted June 18, 2023 Posted June 18, 2023 (UK) I'm after a door / french door (occasional use door) for a narrow opening. (cutting bricks out under an existing window) 1480 wide. ~2100 high. Probably one fixed pane, one opening pane. Side hinge only and outward opening. Perhaps some huffing great single that has a frame not made of wet spaghetti. Keen to avoid the opening being entirely made of frame. White uPVC for self install. House is not a looker or a long term keeper. This would open up some space for access though. Previously I bought some windows from https://www.modernupvcwindows.co.uk but was distinctly unimpressed - the frames have all the structural integrity of wet spaghetti and are as airtight as lace underwear. What profiles/suppliers would you consider?
dpmiller Posted June 18, 2023 Posted June 18, 2023 it's up to the fabricator to remember to insert the steel sections with any profile, I fear.
HughF Posted June 27, 2023 Posted June 27, 2023 I've always been impressed with the offering from Burbage Custom (https://www.modernupvcwindows.co.uk), I'm surprised your experience varied so much from mine. I found the profile from Deceuninck to be decent.
markocosic Posted June 27, 2023 Author Posted June 27, 2023 The fixed windows are ok. Small openers are ok. The French windows are only viable after heel/toe AND and gluing in the glazing. The handles were mismatched by ~4 mm too. The low thresholds are absolutely horrific. Never again. Compare with a cheap rehau frame (e.g. euro 70/total 70) let alone a vaguely decent on (e.g. synergo) and it's absolute night and day. Fine for the odd small window in a house you don't much care about. I wouldn't buy again though.
