GaryBixhall1984 Posted June 1, 2023 Posted June 1, 2023 Hey all - I have the below kit left over from my install - I am in London so let me know if you want anything: - approx 35metres 75mm semi-rigid ducting - 2 x 1.8m lengths of 125mm white rigid ducting - 2 x t-piece 125mm rigid pipe connector - 2 x 90 degree elbow 125mm rigid white connectors - 4 x 125mm jubilee clips - 1 x momentary wall switch for boost mode - some foil backed insulation for wrapping pipes Any ideas what I can do with all this stuff?? Cheers
Blooda Posted June 7, 2023 Posted June 7, 2023 @Sparrowhawk are you still looking ? these are a bit closer than us. @GaryBixhall1984 you may be better in here - market place - Forum | buildhub.org.uk
Sparrowhawk Posted June 7, 2023 Posted June 7, 2023 Thanks for remembering @Blooda! I am still looking, though getting into London is its own kind of nightmare 😀
eandg Posted June 7, 2023 Posted June 7, 2023 On 01/06/2023 at 16:03, GaryBixhall1984 said: Hey all - I have the below kit left over from my install - I am in London so let me know if you want anything: - approx 35metres 75mm semi-rigid ducting - 2 x 1.8m lengths of 125mm white rigid ducting - 2 x t-piece 125mm rigid pipe connector - 2 x 90 degree elbow 125mm rigid white connectors - 4 x 125mm jubilee clips - 1 x momentary wall switch for boost mode - some foil backed insulation for wrapping pipes Any ideas what I can do with all this stuff?? Cheers If you know of anyone with an allotment you'll soon get shot of the 75mm stuff - we had skipraiders in after our offcuts for making French drains. The foil backed insulation is good for pipe lagging if you've still got your plumbing pipe exposed.
Sparrowhawk Posted June 9, 2023 Posted June 9, 2023 On 08/06/2023 at 16:25, GaryBixhall1984 said: @Sparrowhawkwhere are you based? On the coast near Bournemouth
GaryBixhall1984 Posted June 12, 2023 Author Posted June 12, 2023 Ok I can possibly be near Southampton/Portsmouth area over next couple of weeks if that helps!
