GK22 Posted May 25, 2023 Posted May 25, 2023 (edited) Services 1x Zehnder CAQ600 MVHR unit with integrated defrost heater 3,727.93 Services 1x Zehnder LAN C Controller for app smart phone/tablet control 232.16 Services All duct work materials: EPP insulated ducting for intake andexhaust ducts to external metal combi grill. 200mm metal ducting with safe seals to manifolds. 90mm PE antimicrobial and antistatic Semi rigid ducting to plenums. Designer metal Airy air valves throughout. Kitchen valve with integrated grease filter 3,997.99 Services MVHR Design fee 745.00 Services Install ductwork (First fix works) 2,950.00 Services Install MVHR unit (Second fix works) 850.00 Services Commission MVHR system & produce a report for building control 850.00 Please see terms and conditions attached, and note services not carried out by us (eg plumbing, electrics etc), which you will need to ensure are carried out. SUBTOTAL 13,353.08 VAT TOTAL 0.00 TOTAL £13,353.08 TOTAL £13,353.08 Edited May 25, 2023 by jack Tidied up formatting
GK22 Posted May 25, 2023 Author Posted May 25, 2023 Just received this quote for MVHR install. House 335m2, really air tight and well insulated. Please comment.
jayc89 Posted May 25, 2023 Posted May 25, 2023 (edited) Sounds expensive to me. My house is approx 250m2 and DIY cost is coming in at around £3,000 (minus room valves) For a house of your size, I'd seriously consider 2x units. Edited May 25, 2023 by jayc89
jack Posted May 25, 2023 Posted May 25, 2023 Seems very expensive to me. Nearly three grand just for first fix ductwork labour? Without any previous experience, I installed all of my ducting (£289 m2 house) over an easy couple of days with occasional help from my wife. Even at £300 a day (which is a lot given it's a low-skill job), what are they doing for 10 human-days? And what "second fix" works? Surely that's just fitting inlets and outlets? Again, how much time could that realistically take?
Post and beam Posted May 25, 2023 Posted May 25, 2023 Fek that sounds expensive. I bottled out at quoted £6750 and decided at that point i would attempt my own when we get to that stage.
Lofty718 Posted May 25, 2023 Posted May 25, 2023 The quote to install ducting is insane. It's a DIY job imo.
