bmj1 Posted May 21, 2023 Share Posted May 21, 2023 Hi all, We've got our shell erected, brick and block cavity wall construction. I'm looking to retroactively bring our wall u values up, and it looks like drylining with insulated plasterboard is the only realistic option. I was previously hoping to use wet plaster for the "easy" air tightness, but this doesn't appear to be feasible... Any recommendations for how we can best ensure we get decent air tightness with insulated plasterboard dot and dabbed onto concrete blocks? Parge coat? Tape applied where? If anyone can give me a bullet proof spec, that would be awesome. Thank you in advance Link to comment Share on other sites More sharing options...
nod Posted May 22, 2023 Share Posted May 22, 2023 (edited) Many on here swear by Parge But from an airtightness point of view it’s a waste of time It’s better to make sure that the continuous lines of dab are applied around all perimeters sockets and window reveals Acoustic sealant should be applied to ceiling edges also and before you start make sure all joist ends are pointed in tight Pink backed PBS for dabbing Edited May 22, 2023 by nod 1 Link to comment Share on other sites More sharing options...
Big Jimbo Posted May 22, 2023 Share Posted May 22, 2023 I want @nod to do my dot n dab. 2 Link to comment Share on other sites More sharing options...
bmj1 Posted May 22, 2023 Author Share Posted May 22, 2023 16 hours ago, nod said: Many on here swear by Parge But from an airtightness point of view it’s a waste of time It’s better to make sure that the continuous lines of dab are applied around all perimeters sockets and window reveals Acoustic sealant should be applied to ceiling edges also and before you start make sure all joist ends are pointed in tight Pink backed PBS for dabbing wow, awesome, thank you. This should be easy enough to specify and explain with your picture and comments Link to comment Share on other sites More sharing options...
nod Posted May 22, 2023 Share Posted May 22, 2023 14 minutes ago, bmj1 said: wow, awesome, thank you. This should be easy enough to specify and explain with your picture and comments Your welcome Simply repeat around the house Window reveals and heads Parge won’t do any harm Your only looking an afternoon for two spreads to do a four bed home But don’t refer to it as an airtightness layer It will say on the bags Sound coat As soon as you say airtightness They won’t bother solid dabbing the angles Most of The properties that I dot and dab have to achieve a rating of 2 Whilst they big builder saint test many They do test some and we never know which ones Good luck Link to comment Share on other sites More sharing options...
Big Jimbo Posted May 23, 2023 Share Posted May 23, 2023 The problem with @nod is that i think he is a blinking Northerner. Not that i am against them. My wife is One. Just that he ain't coming down to sunny Hertfordshire on the promise of a packet of Hob Nobs is he ? 2 Link to comment Share on other sites More sharing options...
