bends
Tom
Qiuick question: do I need to use a rest bend (https://www.toolstation.com/rest-bend-110mm/p12565?utm_source=Rakuten&utm_medium=affiliates&utm_campaign=4639012565&utm_content=Redbrain&ranMID=46390&ranEAID=pfxNKSnglIM&ranSiteID=pfxNKSnglIM-d6AfLPKasIssE3m68p_otA ) at the bottom of an internal soil stack, or just a standard bend (https://www.toolstation.com/single-socket-bend-110mm/p43723 )?
Also, does it matter if the bend is a double socket, so or should it ideally be a "male" end on the bend, going in to the "female" socket on the pipe run.
Thanks all
Should be a rest bend at the bottom of all stacks.
This.
