Tom Posted May 13, 2023 Posted May 13, 2023 Qiuick question: do I need to use a rest bend (https://www.toolstation.com/rest-bend-110mm/p12565?utm_source=Rakuten&utm_medium=affiliates&utm_campaign=4639012565&utm_content=Redbrain&ranMID=46390&ranEAID=pfxNKSnglIM&ranSiteID=pfxNKSnglIM-d6AfLPKasIssE3m68p_otA ) at the bottom of an internal soil stack, or just a standard bend (https://www.toolstation.com/single-socket-bend-110mm/p43723 )? Also, does it matter if the bend is a double socket, so or should it ideally be a "male" end on the bend, going in to the "female" socket on the pipe run. Thanks all
Temp Posted May 13, 2023 Posted May 13, 2023 Should be a rest bend at the bottom of all stacks. 3 hours ago, Tom said: should it ideally be a "male" end on the bend, going in to the "female" socket on the pipe run. This.
Dave Jones Posted May 14, 2023 Posted May 14, 2023 rest band as a 'foot' on it so you can concrete it upright. 1
