scottishjohn Posted April 16, 2023 Posted April 16, 2023 would it be cheaper to go for spray foam to the 140mm thickness required rather than them cutting sheets to infill studding last time I looked at this I was told that if doing insulation yourself --then cheaper to go pir boards -- but if allowing builder to do it --then the price would be similar or cheaper to go for spray in foam after first fix your comments please.
JohnMo Posted April 16, 2023 Posted April 16, 2023 Spray foam would not give the same u value as PIR board. It would be quicker. Frametherm 32, which is mineral wool would fully fill the studs, way easier than cut boards. Overall although theoretically not as good as cut PIR, may actually in practice give better results. Quick and easy to install, almost zero waste. Way cheaper than both options.
scottishjohn Posted April 16, 2023 Author Posted April 16, 2023 I talked with builder about that --but he says you would then need to use foam backed palster board to get the value not disputing your view on how good it would be --but it will be BC that make the judgment
JohnMo Posted April 16, 2023 Posted April 16, 2023 With only 140mm in the walls was assuming insulation board was being installed as well. What is your planned wall buildup?
nod Posted April 16, 2023 Posted April 16, 2023 No The decision is yours Don’t let BC decide what you are doing Hes there to make sure you achieve the minimum 1
