40 minutes ago, saveasteading said:
No, that is what i meant. I hadn't thought on it before, but the IR is hitting only about a sixth of the body, including one half of the head.
Btw I notice that all IR heaters appear to be made to glow visibly recently.
(Mine is black, with a few tell-tale spots of red where the coating is thin.)
Marketing i expect, but it does remind you to turn it off.
More likely a visual warning that they are scalding hot to the touch, perhaps!?!
around 85-100C.
Infrared panels perform much better when either ceiling mounted or mounted at picture level on walls. The other thing to be aware of is the surface temperature. Herschel infrared heating panels have surface temperatures of around 85-100C. This makes them hot to touch.
