SteamyTea Posted April 19, 2023 Posted April 19, 2023 7 minutes ago, Alan Ambrose said: That's often what happens when you calculate in imperial '.lb2.mph2 is energy in imperial.
Radian Posted April 19, 2023 Posted April 19, 2023 52 minutes ago, ProDave said: Don't under estimate the danger of boiling the water in an UVC, hence why I made a series of small adjustments checking progress after each one. Yes, there's a good reason for those annual checks. Mine's a vented cylinder with 22mm expansion "T'd" off the top so much less of an issue - although accidents have occurred when boiling water has deformed the storage tank in the loft where the vent pipe discharges. Anyway, I've started my own thread about the problems I'm having making use of DHW as an energy store
