2 hours ago, SteamyTea said:
My experience with polyurethane foams and high temperatures is that over time the foam breaks down.
Thanks.  Should I cover the pipes first and then foam around them  ?
Exp foam sometimes makes the pipes creak. For heating pipes, I'd recommend spraying or brushing on something like a silicone lubricant onto the copper pipes first, as a release agent, and them foaming eg so the foam doesn't 'grip' the pipe(s). Likewise with the hot pipe, basically anything which expands / contracts / has a bit of movement.
A chap I knew decided to retro fit exp foam to all of his uninsulated heating pipes throughout the entire first floor, and had to take it all back out a few months later due to how bad this clicking / creaking noise had become.
Not so much of a problem if the foam plug is only a few inches long / deep.
Well as it is the PU breaking down/softening you may be better off just putting a bit of woolen blanket or rubber around them. 5mm of that, then foam.
Try one and see how you get on.
