SimonD Posted March 27, 2023 Posted March 27, 2023 It's been suggested to me to dot & dab the plasterboard over Gyproc Soundcoat plus parge coat where I'd planned battens with service void. How might I regret dot & dab versus battens as dot & dab is going to be both cheaper and quicker. Anybody else able to share some pros and cons?
Chanmenie Posted March 27, 2023 Posted March 27, 2023 36 minutes ago, SimonD said: It's been suggested to me to dot & dab the plasterboard over Gyproc Soundcoat plus parge coat where I'd planned battens with service void. How might I regret dot & dab versus battens as dot & dab is going to be both cheaper and quicker. Anybody else able to share some pros and cons? Whats your wall construction ?
SimonD Posted March 27, 2023 Author Posted March 27, 2023 2 minutes ago, Chanmenie said: Whats your wall construction ? These are brick walls with a small infill extension having used dense blocks
Chanmenie Posted March 27, 2023 Posted March 27, 2023 Dot and dab quick and easy unless you need to cut channels in the dense blocks for cables or pipes. Then the service void with battens would be handy 1
