markocosic Posted March 15, 2023 Posted March 15, 2023 Do you need a support sleeve (will a support sleeve fit in the end of a hep2o reducer manifold? https://www.screwfix.com/p/hep2o-plastic-push-fit-reducing-2-port-closed-spigot-manifold-22-x-15mm/5243f There blank end of these above. I suspect yes but don't want to try demount it (impossible?) to check only to find that the answer is no. @Nickfromwalesdo you know from memory? 1
dpmiller Posted March 15, 2023 Posted March 15, 2023 pretty sure any of the fittings with a male on them have built-in reinforcement 1
Nickfromwales Posted March 15, 2023 Posted March 15, 2023 24 minutes ago, dpmiller said: pretty sure any of the fittings with a male on them have built-in reinforcement +1. 3 hours ago, markocosic said: @Nickfromwalesdo you know from memory? They're 'beefed up' to just be inserted as is. All good . 1
markocosic Posted March 15, 2023 Author Posted March 15, 2023 Thank you! Panic over. My blood pressure thanks you both. 🙂 It's not my house, therefore didn't want any cockup, and woke up in a bit of a flap about why one pair of manifolds (with inserts) were just a touch further apart than the others (an insert further - oh poop I didn't add the inserts on those) Pipes were all marked up when inserted and depthed. Forgot to do that for manifolds as the depth was obvious right...
