Basement sump pump
Hi All,
Any recommendations on bringing toilet and shower waste water to ground level from a basement within residential? Thinking of either saniflow or sump pump installation in basement void below floor. This would be to support a shower room with a toilet, and a separate toilet/sink,
Thanks
C
  • 1 month later...
The troubles with a pump in a sump are firstly you probably wouldn't be insured going that deep and secondly you disturb a lot more ground digging trenches to the sump - plus more cost from more dig, more muckaway, more labour and more concrete.
Whereas a Saniflo type pump is on the surface, boxed in and a lot less heavy to get a wet wipe out when it blocks.
Some macerator pumps macerate wet wipes.
