Post and beam Posted March 7, 2023 Posted March 7, 2023 I believed the Ubbink 400 was a good choice for my prospective house design ( planning granted today !). 200 sq/m requiring 60 l/s, apparently. From the manual the 5 speed settings give the following # 0 = 50 m3/hr, 14 l/s # 1 = 100 m3/hr, 28 l/s # 2 =200 m3/hr, 55.5 l/s # 3 =300 m3/hr, 83 l/s #max = 400m3/hr, 111 '/s I have no way of knowing if the 5 speed settings are equally spaced from 0 to full. So, my 60 l/s would need speed set at 2. Does this look like it will be operating in a quiet enough part of its range to be a wise choice after all? Also, how does the boost requirement of 4 ACH fit into this model As always guys, wise words gratefully taken on board
JohnMo Posted March 7, 2023 Posted March 7, 2023 5 minutes ago, Post and beam said: boost requirement of 4 ACH Where do you get this requirement from? Would normally be a boost of 125% if I recall correctly.
jack Posted March 7, 2023 Posted March 7, 2023 23 minutes ago, Post and beam said: I believed the Ubbink 400 was a good choice for my prospective house design ( planning granted today !). 200 sq/m requiring 60 l/s, apparently. From the manual the 5 speed settings give the following # 0 = 50 m3/hr, 14 l/s # 1 = 100 m3/hr, 28 l/s # 2 =200 m3/hr, 55.5 l/s # 3 =300 m3/hr, 83 l/s #max = 400m3/hr, 111 '/s I have no way of knowing if the 5 speed settings are equally spaced from 0 to full. So, my 60 l/s would need speed set at 2. Does this look like it will be operating in a quiet enough part of its range to be a wise choice after all? Also, how does the boost requirement of 4 ACH fit into this model I have a Brink Excellent 400, which is in the same family of closely-related MVHR units. I have a ~290 m2 house with probably higher than average volume. I'll have to dig it out to be sure [which I've now done and corrected the following number], but I believe our calculated base rate was 180 225 m3/hr, which seems low compared to what you're aiming for given your floor area. Either way, I never run it on anything like that. I think it's currently set on 80 m3/hr, and stays like that 24/7 unless I manually boost it when cooking or we have a lot of people over. We never have problems with condensation and the bathrooms dry out fast enough that I don't bother with a humidity-based boost (I'd have set it up, but one of the decorators we had in decided to step on a cardboard box to reach something. It collapsed, which caused him to smash the humidity sensor that was in the box. I was only 80% sure it was him when I found it a couple of days later, so unfortunately I wasn't able to clearly place the blame). Can you adjust the rate away from those manual setting defaults? I believe we were able to do so for ours at a resolution of maybe 5 m3/hr.
Post and beam Posted March 7, 2023 Author Posted March 7, 2023 16 minutes ago, JohnMo said: Where do you get this requirement from? Would normally be a boost of 125% if I recall correctly. It came from 1.27 of part F. However, having just re read it i think i misunderstood. Its been a long day. Purge ventilation rather than boost as i stated means opening the windows. 2
Post and beam Posted March 7, 2023 Author Posted March 7, 2023 10 minutes ago, jack said: I have a ~290 m2 house with probably higher than average volume. I'll have to dig it out to be sure, but I believe our calculated base rate was 180 m3/hr, which seems low compared to what you're aiming for given your floor area. The 60l/s figure comes from the quote i have from Regavent. also .3 x area which is 200 m3 in my case. As per another post i raised, with no other knowledge to base my figures on i have been using the 60 l/s. I have read such good things about the Brink/Ubink 400 that i would be amazed if it were not suitable and your comments bear that out.
Nickfromwales Posted March 7, 2023 Posted March 7, 2023 1 hour ago, jack said: Can you adjust the rate away from those manual setting defaults? I believe we were able to do so for ours at a resolution of maybe 5 m3/hr. Yup, on the Brink stuff, but a pretty generic function. 1 hour ago, Post and beam said: It came from 1.27 of part F. However, having just re read it i think i misunderstood. Its been a long day. Purge ventilation rather than boost as i stated means opening the windows. You were probably just giddy from the good news 1 hour ago, Post and beam said: Regavent 👎
Post and beam Posted March 8, 2023 Author Posted March 8, 2023 Hi Nick Agree no to Rega-vent. Their unit looks like rubbish when you see inside it. I had the joy of seeing one of their part finished installs recently as well. I could not commit to spending £7k on that. So i used that figure and priced up a kit of parts for a Brink 400 and 90mm ducting. That appears to come to about £5k. This would leave me £2k to get it commissioned and signed off and i would be no worse off financially but would have a top notch install.
