SteamyTea Posted May 8, 2023 Posted May 8, 2023 11 minutes ago, canalsiderenovation said: can see numbers 1-5 Turn it up to 11. 1
Nickfromwales Posted May 8, 2023 Posted May 8, 2023 Remove the sticker ( POWER OFF AT ALL TIMES!! ) and turn the immersion down from 5 to 4. Test after 24 hrs to see where it settles. Re-adjust as necessary each 24hrs until you're happy. 1
canalsiderenovation Posted May 8, 2023 Author Posted May 8, 2023 That's what it is at the moment so I'm going to turn it down a bit.
Nickfromwales Posted May 8, 2023 Posted May 8, 2023 4 minutes ago, canalsiderenovation said: That's what it is at the moment so I'm going to turn it down a bit. May the 4th be with you.... 1
SteamyTea Posted May 8, 2023 Posted May 8, 2023 16 minutes ago, Nickfromwales said: May the 4th be with you.... Set it to Richard.
