Stoo Posted February 7, 2023 Share Posted February 7, 2023 I had an architect plan the layout of my self-build house, but I want to change it before fitting out the interior. There has to be a downstairs toilet, but can someone link me to the regulations for it, in England, please? Link to comment Share on other sites More sharing options...
Blooda Posted February 7, 2023 Share Posted February 7, 2023 (edited) Try this:- Approved Document M: Volume 2 - Buildings other than dwellings - Part M - Access to and use of buildings - Planning Portal The Building Regulations 2010: The Merged Approved Documents (publishing.service.gov.uk) Part M - Page 1190 Sanitary facilities WC facilities - Page 1195 Needs to read in conjunction with "Circulation areas and internal doorways" Page 1194 The above are for none dwellings but similar for dwellings:- Page 19 BR_PDF_AD_M1_2015_with_2016_amendments_V3.pdf (publishing.service.gov.uk) Quite a bit of reading. Edited February 7, 2023 by Blooda 1 Link to comment Share on other sites More sharing options...
Susie Posted February 7, 2023 Share Posted February 7, 2023 Don’t forget which way to hang the doors into hall not into room. and if you don’t like that swap after you get completion certificate. 1 Link to comment Share on other sites More sharing options...
joe90 Posted February 7, 2023 Share Posted February 7, 2023 1 hour ago, Susie said: Don’t forget which way to hang the doors into hall not into room. and if you don’t like that swap after you get completion certificate. However I did hang mine into the room but the BCO said the room was so big it was ok as anyone collapsing off the loo would not be in front of the door (and he added “you will only change it back again after I leave if I make you change it!!!”) 2 Link to comment Share on other sites More sharing options...
Pocster Posted February 7, 2023 Share Posted February 7, 2023 I ignore everything and just do what I want . Bco hasn’t been for sometime 😎👍 1 Link to comment Share on other sites More sharing options...
Stoo Posted February 7, 2023 Author Share Posted February 7, 2023 Great. Found out what I need. Thanks all. Link to comment Share on other sites More sharing options...
