Jimcub Posted January 19, 2023 Author Share Posted January 19, 2023 On 06/01/2023 at 10:53, Nick Thomas said: Most battery or hybrid inverters will come with an EPS output that lets you tap the batteries from a separate circuit. Easy enough to attach a consumer unit to it and move the lights, at least, onto it. I currently have a simple double socket in the loft that'll work in the event of a power cut - it cost £20 extra at install time. More complex options per https://www.deegesolar.co.uk/eps_for_solar/ You definitely don't need tesla stuff to get it done. I have all the connectors that came with battery and inverter, so could power house lighting circuit as we have all led bulbs. it’s something I’ll do in future as it’s a new install, I want to see what I can generate for this year. My installer said a double socket is easy to do with my equipment, a full fuse board is more expensive as more equipment is needed to cope, also I’ll add another battery Link to comment Share on other sites More sharing options...
Nickfromwales Posted January 20, 2023 Share Posted January 20, 2023 On 05/01/2023 at 20:46, CalvinHobbes said: When will other companies catch up? I doubt they are in a rush..... Constant remote-controlled grid charge / discharge beats the crap out of your battery. You get to replace it at your cost, they walk away the better in the end. IIRC Tesla have the gateway, a costly item and a very slow changeover from grid down to UPS on. Much better hybrid stuff out there for a LOT less money. Link to comment Share on other sites More sharing options...
Gone West Posted January 20, 2023 Share Posted January 20, 2023 7 hours ago, Nickfromwales said: I doubt they are in a rush..... Have you got hiccups? 😃 1 Link to comment Share on other sites More sharing options...
Jimcub Posted January 20, 2023 Author Share Posted January 20, 2023 10 hours ago, Nickfromwales said: I doubt they are in a rush..... Constant remote-controlled grid charge / discharge beats the crap out of your battery. You get to replace it at your cost, they walk away the better in the end. IIRC Tesla have the gateway, a costly item and a very slow changeover from grid down to UPS on. Much better hybrid stuff out there for a LOT less money. Probably finger stutter I get that some times, think it’s an age thing. Link to comment Share on other sites More sharing options...
