2 hours ago, PeterW said:
Ok I would go back and confirm with them as they are normally pretty good and this may just be an oversight.
I spoke to the joist designer and he said they went the size below so they wouldn’t be taller than my RSJ.
They stated as long as they are more than 2/3s of the depth of the joist they are fine.
Rang the building inspector and he was happy with this if Pasquills confirmed
I had a pasquill floor, they specified noggins between the joist ends to stop rotation. Did they send you a floor plan?
Hi all (again)
Have a couple more questions if anyone could help
I need to fix my strong backs with 3.1x75mm long galvanised ring shank nails but when I put them in google all I get is the paslode nails. Could anyone recommend any similar suitable ones from Screwfix /toolstation… I found these are these suitable?
https://www.screwfix.com/p/easyfix-annular-ring-nails-3-75-x-75mm-1kg-pack/18793
Next question, I need to put noggins between a few joists to support a stud wall above. I think I need something called z brackets, are these them?
https://www.strongtie.co.uk/en-UK/products/slotted-z-clip-zs
Will standard CLS 63 x 38mm
timber be suffice for this?
sorry for the simple questions but I want to make sure it’s done right
Many Thanks
Screwfix are expensive for nails in my experience,  I've used this company. https://bulldogfix.com/collections/framing-nails  good nails at a decent price.
For noggins supporting walls I skew nailed them into place, those strongties look good as a manufactured alternative.
The noggins I used came with the floor as a kit but 38x63 is about right, or 3"x2" equivalent would be bomber IMO.
Hope that helps
Just realised you might not have a nail gun in which case screwfix nails are fine. I'd use 90mm long.
Not being that skilled, I really appreciate the screws that come with a head that is so precisely made that the screw sits on (even under) the head as if magnetised.
And an ultra sharp point
Philips Ulti-mate my favourite.
Leaves another hand free to hold on to the ladder, and don't drop many.
