Marvin Posted December 20, 2022 Share Posted December 20, 2022 On a 12v 860Watt PV panel system do the panels need grounding to earth? The charger/inverter is charged by the mains. The panels supply some 12v power for the batteries. The inverter only supplies 240v to a non-mains circuit. No panel earth point indicated on the inverter charger. The inverter/charger relays the, mains/battery power supply earth, depending on the supply. I have an earthing rod ready... Link to comment Share on other sites More sharing options...
SteamyTea Posted December 20, 2022 Share Posted December 20, 2022 No. Unless the manufactures instructions say so. And that would almost certainly be the inverters MI. 1 Link to comment Share on other sites More sharing options...
Marvin Posted December 20, 2022 Author Share Posted December 20, 2022 6 minutes ago, SteamyTea said: No. Unless the manufactures instructions say so. And that would almost certainly be the inverters MI. MI ? Link to comment Share on other sites More sharing options...
Radian Posted December 20, 2022 Share Posted December 20, 2022 Manufacturers Instructions I expect. Does the inverter say if it's transformerless? Link to comment Share on other sites More sharing options...
Marvin Posted December 20, 2022 Author Share Posted December 20, 2022 Transformerless? er... This one. https://uk.renogy.com/3000w-12v-pure-sine-wave-inverter-charger-w-lcd/ Link to comment Share on other sites More sharing options...
