gaz_moose Posted December 10, 2022 Share Posted December 10, 2022 i have 2 bedrooms that are the same size and L shaped, in bedroom 1 i fitted a p+ radiator up the corner and in bedroom 2 i fitted a short but wide k1 radiator along the main wall. the BTU's are about the same but bedroom 1 never seems to heat up, whereas room 2 is perfect.( they both have the same walls/windows/insulation etc). Bedroom 1 has a 500w X 600h radiator with a btu of 2310, if i fit a 500w X 750h with a BTU of 2651 would it make a real world difference? I know the problem lies in me putting the radiator up the corner but i cant really change that now. i don't want to have to alter the pipework which comes up through the floor. my current pipe centres are just over 60mm from the wall so i cant stick a K2 on. i could probably use one of those cheap column rads but its a plasterboard partition wall and id worry about it falling off. sorry about the essay, i just don't know what my best way to proceed is 😒 Link to comment Share on other sites More sharing options...
TonyT Posted December 10, 2022 Share Posted December 10, 2022 Change the btu to watts, easier for you to compare get an electric fire and heat the space, then change the watts into BTU Link to comment Share on other sites More sharing options...
gaz_moose Posted December 10, 2022 Author Share Posted December 10, 2022 i dug out my original notes on the subject. id calculated that i needed 547 watts. the rad i fitted was 677 watts. in bedroom 2 the rad is 772 watts, So i can see why that helps it to be warmer. i figured it was all down to the better placement. the 750 high rad is 777 watts which puts me in the same league as bedroom 2 but i think the radiator being wedged up one corner is the deal breaker. Link to comment Share on other sites More sharing options...
bassanclan Posted December 10, 2022 Share Posted December 10, 2022 Have you checked the flow rate temperatures to and from each radiator? It may be a lockshield needs adjusting Link to comment Share on other sites More sharing options...
gaz_moose Posted December 11, 2022 Author Share Posted December 11, 2022 the radiator gets boiling hot so i assumed it wasn't a flow problem. Link to comment Share on other sites More sharing options...
