jfb Posted December 9, 2022 Posted December 9, 2022 My LG washing machine is leaking from directly underneath the machine during the end of the wash (spinning I guess). It has an access point at the drain that is clear of debris and it is draining ok. No obvious filter to check. Anyone know what might be causing it?
ProDave Posted December 9, 2022 Posted December 9, 2022 My guess would be the rubber that connects the drum to the front of the machine (someone will come along and tell us the correct name for it) has got a split near the top that only leaks when spinning, when water is getting splashed around a lot and it is at it's worst movement. That is only a guess. If it is, on some machines it is an absolute bitch of a thing to change.
jfb Posted December 10, 2022 Author Posted December 10, 2022 Thanks for the reply. At least I can use it with a tray underneath at the moment!
