What are these funny 3 bits with the fresh air feeds
The plastic fittings are used to direct the airflow away from an area, To use them you need to screw the valve out by approx 80% and slide into the slots on the top of the valve, when commissioning the system you adjust the valve, lock with locknut and fit valve in the desired direction.
Gary
BPC Ventilation
  • Like 6
