osmononame Posted December 4, 2022 Posted December 4, 2022 Hi. Looking to see if anyone knows how I would adjust one of these hinges so the door moves per the arrows. I've tried playing about with the hinge and can't get it to go up and down but nothing re right to left.
markc Posted December 4, 2022 Posted December 4, 2022 Pretty sure you have to pack those hinges to get left/right movement
osmononame Posted December 4, 2022 Author Posted December 4, 2022 That's what I was dreading! Means I have to take the door off the hinges and it's a big + heavy door!
craig Posted December 6, 2022 Posted December 6, 2022 You shouldn't need to take the door off the hinges, the black section should slide, Loosen the fixings and then push them up/down and it should give you the relevant movement you need left/right. I'm not certain of the exact hinge but it certainly indicates this to be the case.
