I’ve got an insulation job coming up where I will need to stick a load of PIR board between floor joists and stud wall battens. Board will be a friction-fit to some extent, but I need to seal round the edges and prevent it slipping.
Also I have various drafty gaps to fill where electrical cables and pipes penetrate blockwork. I was planning to use gun foam products, but can I get away with just one type?
e.g. Soudall Soudafoam window&door SWS foam - can I use this to do both jobs?
5 hours ago, Dave Jones said:
Ilbroook foams are expensive but very good
Unless you buy them on Ebay.
(That sentence works both ways... not so expensive, but potentially not so good - from what I've read on BH)
