Temp Posted November 3, 2022 Posted November 3, 2022 Some self builders are partly filling studwork with PIR leaving a void for services. Seems insulation contractors don't think its wise to use PIR around ducts... https://www.constructionenquirer.com/2022/11/02/contractors-call-for-ban-on-indoor-use-of-pir-board/ Quote Contractors call for PIR board ban on internal ductwork Insulation contractors are calling for an immediate ban on Polyisocyanurate (PIR) based insulation being used in internal ductwork applications on safety grounds. Rigid PIR foam insulation is commonly used on external ductwork. But the Thermal Insulation Contractors Association is warning that PIR is also combustible and can pose a danger when used on internally located ductwork. Safer alternatives, such as phenolic duct insulation, are more expensive and, TICA fears that some contractors are using PIR insulation inside buildings to cut costs in the face of rising economic inflation. It is demanding that the internal use of PIR be brought to a halt and is also calling for firms awarding contracts to carry out more stringent checks that the correct insulation materials are being installed inside their buildings. Chris Ridge, TICA’s technical policy manager, said: “Are contractors who continue to use PIR boards on internal duct systems wilfully turning a blind eye or are they ignorant of the facts concerning the products they are installing? “Either way, the use of PIR board on internal ductwork systems needs to end. The current economic climate, where spiralling costs are impacting many businesses, is no excuse for prioritising the use of cheaper, potentially dangerous materials at the expense of people’s safety.” He added: “The responsibility for ensuring compliance cannot begin and end with the specialist contractor and those awarding such contracts need to play their part. “In the case of thermal insulation, mechanical and electrical contractors should be checking the credentials of the insulation product applied and asking more questions of their insulation contractors.”
Andeh Posted November 6, 2022 Posted November 6, 2022 I don't know enough about PIR, is this in case of another grenfel fire spread issue?
Temp Posted November 6, 2022 Author Posted November 6, 2022 50 minutes ago, Andehh said: I don't know enough about PIR, is this in case of another grenfel fire spread issue? Yes I think so. They appear to be concerned that an electrical fire could spread to the insulation.
Nickfromwales Posted November 6, 2022 Posted November 6, 2022 22 minutes ago, Temp said: Yes I think so. They appear to be concerned that an electrical fire could spread to the insulation. And the rest of the house / building materials will be safe from the spread of this fire, how, exactly?
Radian Posted November 6, 2022 Posted November 6, 2022 I'm guessing it's spread of fire from flat to flat through ducts that they're concerned about?
