Hi All
In my renovation project I will be having a complete new concrete slab and the floor build up will be:
250mm Hardcore/Sand layer
DPM
150mm Concrete
200mm PIR Insulation
UFH Pipes
50mm Screed
My question is whereabouts within this slab buildup is best to run services? This includes:
Power to the kitchen island (going to put a duct in for it)
Water supply (in new blue pipe) Happy to duct this also
Another question would you expect to have A393 mesh in the 150mm concrete?
All replies very much appreciated
8 hours ago, richo106 said:
150mm Concrete
UFH Pipes
50mm Screed
Why not passive slab? (100 to 150mm concrete on 200mm PIR on hardcore)
That's a question your SE should answer, and if you don't want to have one, at least BC needs to yay it.
I'd use 300mm EPS rather than PIR. It's cheaper and would save you some hardcore.
Typically 150mm doesn't need reinforcement. 100mm concrete with reinforcing fibers is usual for mass house builders around here with no screed. Just some SLC if needed for vinyl flooring afterwards.
