Lintel under wall plate - or better option?
Was going to tackle the cut-out through to my new extension this weekend.
I was thinking of removing the outside section and putting a single 100x140 Lintel under the wall plate. It would form a kind of door header. Anyone think of a neater idea?
IMG_5006.thumb.jpg.89a09625864ce69ae5ef6cf467592ff6.jpgIMG_5007.thumb.jpg.ef3218c110d03a190f23183f809117ed.jpgIMG_5005.thumb.jpg.1a310eeeef6baf844a02a4385ea91e7b.jpg
If you are not wanting to see the lintel or struggling for head height then a steel angle (galvanised) under the wall plate and up behind it would be neat.
do you need a lintel? If the wall plate isn’t supporting anything at that point then it won’t need a lintel
Thanks @Marc Will have a look into that steel.
Wall plate has the 3 trusses sitting on it from main roof. It's just going to be a hallway into new bedroom, head height should still be plenty.
Old pic but should show what I mean.
