WWilts Posted October 3, 2022 Posted October 3, 2022 (edited) If a raised patio is laid above weep hole level, how to let the damp out of the weep holes? And how much does it matter if a section of weepholes is blocked up? How is this challenge designed out usually? Edited October 3, 2022 by WWilts
markc Posted October 3, 2022 Posted October 3, 2022 Weep holes should be at DPC level so you definitely should not be going above them. Or are these weep holes in a retaining wall, not habitable? Is so then you can add a sort of French drain with pebbles to allow the drainage to continue 1
Miek Posted October 4, 2022 Posted October 4, 2022 My weeps are at dpm not dpc, dpc is 1 block above the bottom of the cavity (I'm in a radon area so the dpm runs over the cavity and into the outer skin) The weeps at ground level are there to release water but in reality they should remain dry if the wall is waterproof. If they are below grade and draining into porous material I'd say that's fine. 1
markc Posted October 4, 2022 Posted October 4, 2022 23 minutes ago, Miek said: My weeps are at dpm not dpc, dpc is 1 block above the bottom of the cavity (I'm in a radon area so the dpm runs over the cavity and into the outer skin) The weeps at ground level are there to release water but in reality they should remain dry if the wall is waterproof. If they are below grade and draining into porous material I'd say that's fine. Yes, my bad, was supposed to say DPM .. ie to drain the membrane 1
WWilts Posted October 4, 2022 Author Posted October 4, 2022 So, covering up weepholes with patio hardcore is a no-no.
markc Posted October 4, 2022 Posted October 4, 2022 13 minutes ago, WWilts said: So, covering up weepholes with patio hardcore is a no-no. If the hardcore will bridge a DPM then it’s a no no or you will get damp walls. You could leave a gap between wall and patio. if the weep holes are in a retaining wall (damp rising is not a problem) you could use a clean crusher run (concrete,brick,stone pieces) not Type1 which will allow the weep holes to drain. This will create a sort of French drain, type 1 could be used under rest of patio. 1
