benben5555 Posted September 20, 2022 Share Posted September 20, 2022 Hi, has anyone got a design detail for a casement window in a timber frame with weatherboard cladding. Specifically I'm interested in the vertical junction of the cladding and window. There is normally a vertical timber between the two but I'm not sure how it all goes together. Thanks Link to comment Share on other sites More sharing options...
Bonner Posted September 21, 2022 Share Posted September 21, 2022 That is a fine detail not on our drawings, something the joiner has to work out in situ. Haven’t got a picture but basically he made a timber frame (Larch in our case) top and sides with the bottom being the cill. 1 Link to comment Share on other sites More sharing options...
DevilDamo Posted September 21, 2022 Share Posted September 21, 2022 Have you tried here… http://www.silvatecdesign.com/Technical Downloads/Silvatec Design Standard Details - September 09.pdf 1 Link to comment Share on other sites More sharing options...
Lilly_Pines Posted September 23, 2022 Share Posted September 23, 2022 Here are some details with accompanying 3D illustrations: https://www.firstinarchitecture.co.uk/detail-post-timber-cladding-details/ The horizontal cladding detail includes external insulation but I don't think it would change that much without it; the finishing strip would just be less wide. 1 Link to comment Share on other sites More sharing options...
benben5555 Posted September 24, 2022 Author Share Posted September 24, 2022 18 hours ago, Lilly_Pines said: Here are some details with accompanying 3D illustrations: https://www.firstinarchitecture.co.uk/detail-post-timber-cladding-details/ The horizontal cladding detail includes external insulation but I don't think it would change that much without it; the finishing strip would just be less wide. Perfect, thanks. That is what I had envisaged, but I was concerned that water would get in any small gaps between the finishing strip and the cladding, so I wasn't sure if there would be a hidden flashing or something in there. Doesn't look like it, so I guess it is important to make sure your breather membrane is property detailed and the cavity well ventilated and drained. Link to comment Share on other sites More sharing options...
