WWilts Posted September 10, 2022 Posted September 10, 2022 DPC installed above external ground level. Can the internal finished floor level be raised above such a DPC?
WWilts Posted September 10, 2022 Author Posted September 10, 2022 DPC in pic. 150mm above external ground level. DPM will be lapped/attached to this DPC. Question: Can the internal finished floor level be higher than this DPC?
Andeh Posted September 10, 2022 Posted September 10, 2022 As long as there is an uninterrupted barrier for damp blocking, you will be fine. 1
WWilts Posted September 10, 2022 Author Posted September 10, 2022 5 hours ago, markc said: I’m struggling to understand the question pic above to help clarify 1
Temp Posted September 10, 2022 Posted September 10, 2022 13 hours ago, WWilts said: DPC installed above external ground level. Can the internal finished floor level be raised above such a DPC? I can't see the drawing but think the answer is yes. After all the first floor is always way above the DPC 🙂 1
