Crowbar hero Posted August 23, 2022 Share Posted August 23, 2022 I have a design with a stud wall running parallel and pretty much right in between a pair of floor joists - should I try to jam an extra parallel joist under the wall, or simply increase the quantity of noggins between the affected joists..? Link to comment Share on other sites More sharing options...
Gus Potter Posted August 23, 2022 Share Posted August 23, 2022 23 minutes ago, Crowbar hero said: I have a design with a stud wall running parallel and pretty much right in between a pair of floor joists - should I try to jam an extra parallel joist under the wall, or simply increase the quantity of noggins between the affected joists..? Have a look at the design. It may be that althought the wall is not carrying vertical load it is carrying horizontal load from say the wind blowing on the outside walls? Best thing you can do is to provide more info to get a more defined answer. Link to comment Share on other sites More sharing options...
nod Posted August 24, 2022 Share Posted August 24, 2022 6 hours ago, Crowbar hero said: I have a design with a stud wall running parallel and pretty much right in between a pair of floor joists - should I try to jam an extra parallel joist under the wall, or simply increase the quantity of noggins between the affected joists..? Anywhere that studs land between joists should have nothings between each joist and under the floor deck every 600 You can do this from underneath by following the screws 1 Link to comment Share on other sites More sharing options...
Crowbar hero Posted August 24, 2022 Author Share Posted August 24, 2022 20 hours ago, Gus Potter said: Have a look at the design. It may be that althought the wall is not carrying vertical load it is carrying horizontal load from say the wind blowing on the outside walls? Best thing you can do is to provide more info to get a more defined answer. the wall is internal, and not load-bearing. Its on the first floor of a conventional extension with block walls and truss roof. Link to comment Share on other sites More sharing options...
