People of the masses !
What fixings should I use to get this basin on the wall ?
Assume some bracket/ thread type thing it hangs on ???
Should be in the box with it ..?? There should be nylon top hats (usually eccentric for adjustment) that go through the big holes.
Nope nothing . Did think it was strange - assume you’d get something . Failing that the rather expensive tool station bracket would do ?
  • 3 weeks later...
Finally got round to this .
Had to sink ( pun not intended ) the bolts right into the wall leaving a fixing that’s too short . Thickness of sink is 30mm - barely that on thread left let alone washer then nut . Presumably I simply need a longer threaded bolt .
Surprised they expect the sink to just go straight to the wall I.e no rubber packer or similar . As my tiles are not flat I might put exactly that in there .
Edited by pocster
