Olf Posted July 31, 2022 Posted July 31, 2022 (edited) Today I came across 2 cans of foam clener that do not want to squirt the magic potion: one No Nonsense bough last week, used once (and was ok!). Today I can feel it is full of goodnes and hear it slushing inside yet not coming out - not in the gun, not with the nozzle, nor when persuaded with a screw. Another one: posh Ilbruck AA290. The same symptoms Was used about a month ago, today no response. What am I doing wrong? Edited July 31, 2022 by Olf typos
Simplysimon Posted July 31, 2022 Posted July 31, 2022 (edited) gas leaked? it's just acetone Edited July 31, 2022 by Simplysimon adding constituent
Olf Posted July 31, 2022 Author Posted July 31, 2022 1 minute ago, Simplysimon said: gas leaked? That would make sense, though if gas could leak, why not the solvent itself (both cans are heavy) Is there a non-destructive way of checking that?
Simplysimon Posted July 31, 2022 Posted July 31, 2022 turn can upside down and press nozzle with fingernails to allow cleaner out?
Simplysimon Posted July 31, 2022 Posted July 31, 2022 i've had a couple of the illbruck and used on/off over a few months with no issue, to be fair haven't used a lot as illbuck foam doesn't seem to block nozzle as much as others.
Conor Posted August 1, 2022 Posted August 1, 2022 I went through hundreds of cans of foam and half a dozen cleaners. Failure rate was at least 1 in 10. The B&Q no no sense we're the worst. Sent not several back, all loosing gas before use. After then I always gave the cans a good hard squeeze in the shop!
