Hi all,
A few months back I found a recommended kit in this forum, but have long since lost the link.
We are building at present, and one day in the future, will be able to afford a heat-pump to heat / cool the 30m2 of kitchen / diner we are building.  So for now, all I really need is a pipe kit, and manifolds (I think).  I understand spacing should be 150mm when a heat-pump will be used.
The floor make-up is block/beam, 75mm insulation, 60mm screed.
Any kit recommendations would be greatly appreciated :)
Tim
Is that under building regs as that seems too thin. Wunda do kits to a size with all that you need in them.
It is, the calculation came out at 70mm but we could get 75mm readily, so did!
Heard Wunda mentioned before, will take a look.
Thanks
  • 5 months later...
I eventually went for a Wundu kit.  It arrived quickly, was well priced, had a good branded pump, and generally seems to be a great kit.
