Evening all,
One of the next jobs on my list is to get a pair of 28mm pipes out through an external cavity wall to the boiler that's mounted in an outside steel housing, which sits about 2 inches from the rendered external wall.
I am wondering on how best no do this, I'm sure others on here will have a good solution.
My current line of thought is to run pipes in a pair of plastic ducts, say 68mm (ie bit of downpipe), with 19mm pipe insulation. Then somehow seal the inside end to the plaster ( for airtightness).
Or perhaps run both pipes in a single larger duct?
To get the flexi pipes to my ASHP I core drilled 2 x 80mm holes and used pipe insulation with 75mm OD from the unit right through to the inside and sealed to the plaster skin with flexible silicone.
+1, but I would have sleeved ( ducted ) the pipes as it’s a cavity.
