I’ve just completed the upstairs stud-partitioning for our new build. I’m going to line them with 18mm OSB before plaster boards.
Can anyone advise me on whether I need to line the walls with waterproof chipboard which I’ve put down for the flooring for the whole of upstairs as opposed to the OSB?
Also do I need a different plasterboard for the bathroom and en-suite and do the shower walls get lined with something else that I’m unaware of?
Any advice would be appreciated.
Arnold9801
Gypsum backer board outperforms most boards for shower rooms
and is much easier to work with than cement board
As a tiler I would use standard moister plasterboard in all wet areas
Even wet rooms that are being tanked
If water penetrates the tanking membrane It really doesn’t matter what is under there
