Arnold9801 Posted June 21, 2022 Posted June 21, 2022 I’ve just completed the upstairs stud-partitioning for our new build. I’m going to line them with 18mm OSB before plaster boards. Can anyone advise me on whether I need to line the walls with waterproof chipboard which I’ve put down for the flooring for the whole of upstairs as opposed to the OSB? Also do I need a different plasterboard for the bathroom and en-suite and do the shower walls get lined with something else that I’m unaware of? Any advice would be appreciated. Arnold9801
nod Posted June 22, 2022 Posted June 22, 2022 Gypsum backer board outperforms most boards for shower rooms and is much easier to work with than cement board As a tiler I would use standard moister plasterboard in all wet areas Even wet rooms that are being tanked If water penetrates the tanking membrane It really doesn’t matter what is under there 1
